- pigman1Explorer
jrp wrote:
X2!!!
If its a 4 wheel drive model, then yes, you can tow it 4 wheels down, by putting the transfer case in neutral (not the auto transmission).
The detailed instructions are in the owners manual.
If its a 2 WD version, no you can not tow it 4 wheels down, without modifications.
Pulled a 4x4 auto trans about 80,000 mi before we switched to the 4x4 1500. - jrpExplorerIf its a 4 wheel drive model, then yes, you can tow it 4 wheels down, by putting the transfer case in neutral (not the auto transmission).
If its a 2 WD version, no you can not tow it 4 wheels down, without modifications. - YajExplorerWe have a 04 Colorado 4X4 Crew Cab. Its the 4 wheel drive transfer case that gets switched to neutral, then it can be towed 4 down.
I don't think a 2 wheel drive can be towed 4 down, I don't think the transmission gets lubed unless the engine/input shaft is turning.
I think you could put a drive shaft disconnect on it if one is available.
About RV Newbies
4,032 PostsLatest Activity: Aug 28, 2025
