LarryJM
Jul 31, 2016Explorer II
legerh wrote:
We are upgrading from a tent trailer to either a Hybrid or Travel Trailer. We have a 2013 Ford Explorer with the towing package - 5000 lb towing max.
I am not sure how to determine the towing capacity as I have had different answers from different sales people. Should I be using Unloaded Vehicle Weight and then try to estimate how much we will carrying in the trailer? Does the UVW include the Dry Hitch weight or does that get added on too?
Finally, I am not sure how to determine the appropriate length to tow safely. We looked at a Salem Cruise Lite 261BHXL with UVW 4537 lb and a cargo carrying capacity of 2897 lb - GVWR is 7434 lb We would not be filling it with water, however, before we arrived at the campsite.
The length is 29'1". I am not sure how to determine the appropriate/maximum length to tow safely either. The salesperson assured us that we could tow this trailer but my gut instinct is that it is too big.
Help!! This is all new and I am not sure how to determine the maximum unloaded vehicle weight or the length that we could safely tow.
Unfortunately you have what I would consider one of the least capable towing vehicles made. Short WB, lightweight, and narrow track width all work against you. The trailer you are looking at IMO is WAY OUTSIDE your TV capabilites and what you have now or something in the 20' range with a UVW under 3500lbs is going to be about your max and then if a full profile trailer could be questionable because of aerodynamic handling issues.
My recommendation is to stick with what you have and first look at upgrading your TV to something more capable first and then look to upgrade your trailer.
Larry
About RV Newbies
