Ford lists maximum towing capacity for passenger vans based on GCWR - weight of empty van with full fuel and driver, pretty much industry standard for rating passenger vehicles if there are no factors calling for a lower rating. So how much of that maximum is actually available will depend on how much load is in the van. My E-350 with the same engine (but 3.73 gearing) gets a 6000 pound tow rating because the van is just that much heavier.
You can overstrain the engine as tuned for the van, it won't put out any more power than it is designed to put out full time. That's not necessarily the case for some performance tunes in special versions of pickups and some SUVs, but in the van the engine is limited to 100% duty cycle ratings. I don't know about the transmission, which rating of the E4OD got put into the E-150. I would definitely consider an accessory transmission cooler if you don't have the factory tow package with the heavier radiation and cooler from E-250/350 vans.
I suggest locking out overdrive. With the ratios in my E-350 (60-series version of the transmission) and slightly lower final drive, that has me running 2800 RPM at 70 MPH, rather that the 2000-2050 I see in overdrive. For towing, I can live with the extra noise, it is essentially the same RPM my 6.8 V-10 cruises at in overdrive, and means about 40% more HP available as you get to full throttle at that speed.
