SusanDallas wrote:
So, if any of you tow a small travel trailer with a minivan, I would really like some feedback on this travel trailer before I purchase it. Thank you !
I towed a lightweight 17' Scamp travel trailer with a 2006 Toyota Siena six cyl Mini-van.
The Scamp weighed in less than 2,000 pounds and the Sienna had a 3,500 tow rating.
Here's what I learned.
The Sienna could easily tow the Scamp but gas mileage dropped from 22mpg to around 14mpg (on the interstate). Going through the mountains, the engine RPMs stayed high going up, and the brakes got soft going down (electric brakes on the Scamp).
The big problem was with front wheel drive. With the trailer on the rear hitch, it puts the weight is on the rear tires and takes it off the front tires, which means less traction on the front drive wheels.
Pulling out of a steep wet driveway, the front tires would spin - meaning I had to be very careful going up hills.
Also, even with the trailer brakes you could feel the trailer pushing the minivan when stopping.
So yes, while it is possible to pull a travel trailer with a minivan, it won't be fun, it won't be safe, and it will put a lot of stress on the minivan brakes, transmission and engine.
If in doubt, go to your local U-haul and rent a storage trailer. Put a thousand pounds of stuff in it, and take for a two hundred mile drive.
This will give you a good idea of how well your minivan will do with a travel trailer.
Bill
