Playtime_II
Jun 27, 2013Explorer
As a F150/SC/5.4/SB owner, use the sticker on the door, the manual has a table and you would need to know all of the configurations of your truck. A trailer package is unique to the model/year but often comes with a 7-pin elect connection on the rear, a 2" receiver hitch, a transmission cooler, electrical pre-wire for trailer brake controller, maybe more but not tow more. A weight distribution hitch will allow you to tow a heavier tongue weight trailer BETTER as it transfers some of the weight to the front axle (better handling/steering/braking. However, you hitch will be stamped with two weights; using a drawbar (probably 500lb) and a wdh (Probably 1,000 or 1200). Without a wdh, you bumper will drop several inches when you hitch up. My trucks listed stats are:
UVW 5871
Avail Cargo/Hitch 1329
GVWR 7200
GCWR 14500
Gear 3.73
FGAWR 3750
RGAWR 3850
MAX TT 8700
My Rockwood 2902SS was listed as:
GVWR 7598
UVW 5432
Hitch 614
CCC 1833
However...TT loaded with pot/pans/clothes for 3-pax-4days/propane; 1/4 fresh water, no passengers, two bins in the bed I weighed in at:
Steer 3140
Drive 3960
TT 6040
CGW 13140
With a wdh and dual cam sway controll I never had a towing problem even with big rigs, high winds, etc. However, if the fresh water tank was empty and I loaded the rear bunk with gear I did get sway. loaded the TT forward of the axle and I was fine.
Just my data to hopefully educate you.
UVW 5871
GVWR 7200
GCWR 14500
Gear 3.73
FGAWR 3750
RGAWR 3850
MAX TT 8700
GVWR 7598
UVW 5432
Hitch 614
CCC 1833
Steer 3140
Drive 3960
TT 6040
CGW 13140
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
