Paulx's avatar
Paulx
Trailer tire questions
Hi, I have a Salem 181BHXL trailer which has two axles and about 3700 lb dry weight. The tires are H188ST, size is ST205/75D14 which has a max load of 1760 lb @ 50psi. The trailer was delivered from the dealer with 40psi in the tires.
I have not found a table for load/inflation for this tire but the goodyear table has the same sized tire at the same pressure taking the same weight, 1760 lb. At 40 psi it takes 1530 lb.
Just wondering what I should use for my pressure. We don't intend to load this trailer to the gills due to fairly low tow vehicle capacity. Is 40 a good pressure? I know the tires can be unevenly loaded but even with 1000 lb of payload, that's 4700 lb, divided by 4 tires is under 1200 lb per tire which is 25 psi in the load table! Do people really go that low with their tires in light trailers?
  • IMHO take the pressure to the max and maybe 5 over. Don't get fancy with load charts and all of that stuff.
    I've had only one tire shred in my life and I have been towing for over 35 years. Most of the time at 70 to 75 MPH in the heat of summer. Most of the time with cheap China tires. Always on ST tires.
    I attribute my luck to max inflation or max inflation + 5. It keeps the heat down and keeps my tires alive.
    This it what I will keep doing because it works for me. :)
