Qwidda's avatar
Qwidda
Travel trailer advice
Okay, first want to thank those who chimed in their advice/opinions on questions regarding pickup campers.
After further thought, I'm thinking a 20-25 used travel trailer may be a better option for the following reasons:
1. more space (accomodates more people, storage space, comfort)
2. seems to be a simple operation to "park & leave" compared to a cabover
3. a little more self-sufficient/self-contained (thinking larger propane tanks, water tanks, etc.)
Of course a big factor is a place to park it and it looks probable that I've got use of a friend's lot for that.
I'd appreciate any comments from those who've had these trailers and/or campers on the pro's/con's of each.
Also, curious how these are typically heated and what about power? Seems like to run a microwave or other electric stuff you'd need a generator of some sort or can battery power run the electrical items? I think the refrigerators, stoves, heat would be run on propane?
Andone more problem but it's off-topic.
What is the Apple Mac https://whatever-tech.com/best-macbook-pro-mouse-reviews/ equivalent of right click in Reaper? Ctrl+click is assigned to do other things.... and there's lots of stuff that only seems to work if you can right click...
thanks in advance.
  • I hope you have had some luck in figuring out what will be the best choice for you. Here's a website that might also help you with the pros and cons of different rigs.
    http://ourclassceelife.com/the-basics-of-rving/
    Kristyn
  • ppine's avatar
    ppine
    Explorer III
    Some people only park their trailers where they have 120 volt power.
    Some people park all over the place and use generators and or solar power.
    Plan on using lights, refer, some furnace time, those kinds of things when not on shore power, (plugged in to 120v). Microwaves, hair dryers, electric heaters use a lot of power.
    You refrigerator requires some 12 v power even when it is running on propane. Do some reading about how many watts various appliances use on your rig. Good luck
  • Growing up with RVs since I was 7 years old, and now I'm 64, it's hard to imagine someone brand new, who has no experience with an RV. Things I take for granted are tremendous obstetrical for someone who's never been down this road before. But in the end, it's really not all that complicated.
    My parents travel trailer (1963) had a radiant gas heater in it. It took no electricity. Today's RV, pretty much all of them, use furnaces that depend on battery power to control the circuit board and the fan, and propane for the heat.
    My parents trailer had a propane operated light affixed above the gas stove and was the only source of light in the camper. It ran off the propane tanks. Today's RV all run on 12 volt DC (battery) power, but stoves and ovens (for the most part) are still gas, unless you get a camper that's all electric. Lights are all 12 volt DC.
    The older campers never had water heaters, today's do. Water heaters can run on both propane and electric, but still need that 12 volt DC battery to run the circuit board.
    Older campers had 100 percent gas operated refrigerators and took no electricity at all. Times have changed. Today's RV have propane-electric refrigerators. Electric being 120 volt AC house hold current and will switch to propane when the power is off or disconnected. But they still take the 12 volt DC battery to run the circuit board.
    Power awnings, electric tongue jacks, electric or hydraulic stabilizer jacks, outside lights, all, run on 12 volt battery power.
    Today's campers come equipped with a 120 volt AC converter to 12 volt DC battery which charges the battery and also powers the 12 volt DC devices if you have no battery.
    So, what I'm saying is, today's RV's, all ... have a 100% dependency on electricity in order to function. Where you get that electricity is the challenge.
    If camping in an RV park or a campground, more than likely your campsite will have at least electricity. (unless you select a primitive site). But if you prefer to camp off grid (boondock) or primative, you'll need to provide your own electricity, either a generator or solar power. It's just that simple .... but not so simple to implement.
    The days of truly "self-contained" RV is long gone. They have dependency's on electricity now. Boondockers take great strides to modify their RV to make them truly off-grid usable with solar and generators.
  • I have had a trailer. You will want to hook up to power and will need to hook up to power in order to run the microwave and the air conditioner. You can run things like lights for a period of time off the batteries depending on how many batteries you have. We had two batteries. You can increase that time using solar. The refrigerator, stove, water heater and heat run on propane, although they also use some power. For example, the fan for the heater needs power. You can also run the refrigerator on AC when you have it.
    I would suggest that you spend time online and at RV lots looking at different trailers and seeing the features. There will be different features for different RVs.
