valhalla360
Jul 15, 2019Navigator
DallasSteve wrote:
Cons
1 - I would rather drive a Jeep Wrangler than a big a$$ truck.
2 - The motorhome would probably have a generator which I would want to purchase extra for the trailer (still cheaper).
3 - Set up would probably be a little easier with a motorhome + Jeep.
4 - The ability to walk back to the kitchen or bath is nice in a motorhome, but for us it won't matter as much because we won't be making long trips between camps.
1. This is one of the big reasons in my mind to consider a MH...especially if you are into off roading a big 1 ton truck is a lousy platform.
2. A lot of 5th wheels can be had with a generator, so not really a con unless you are set on a model that doesn't have the option...but really if you are staying in parks with power most of the time, a good inverter generator in the truck bed is nearly as good for rare times when you need it.
3. Setup is about the same...assuming THE SAME BELLS AND WHISTLES. You can get autoleveling systems on 5th wheels. Backing into a site, you still have to disconnect the toad on the MH. Both you still have to hook up the utilities exactly the same. If you are moving a couple times a week, after the first month, backing into a site is just as easy with either (it's the weekender who does it 2-3 times a year that struggles as they don't develop a good feel for backing)
4. Absolutely agree. Unless you are doing long road trips in a short time, the ability to walk back to the kitchen/bathroom is over rated.
About RV Newbies
