AmericaOverland's avatar
Jan 16, 2015
Potentially bad situation
I'm in a bit of a bind here in southeast Texas. I'm going to Elgin, near Austin in less than two weeks, maybe a lot sooner if I have a solution.
I have a hybrid travel trailer, the worst mistake I've made in buying a travel trailer. The foldout door leaks in water because of a break in the seal, near where the hinge starts. It happened because the dang factory cut the bed foldout door edge trim a little too long towards the seal, so when it would fold up, the end of that edge would gouge into the seal and bend, cutting out a chunk of the seal and letting water in. I tried to fix it by cutting that edge shorter like it is on the other side and putting some caulk in the part of the seal that was gouged out. Turns out it was the wrong caulk...
Now, I have water damage in the wood behind the sofa bed where the leak it, and mold in the storage compartment...
I also sprung a leak in the back right corner of the roof where the sealant failed, and I tried to fix it, but the yahoo at HD didn't know his sealants... It just came apart like rubber in places, and like cake icing in other places. I just scraped all this off, and I need to go into town and pick up the stuff that will let me chemically strip this stuff off without damaging the rubber roofing, before applying the right sealant.
I posted this here in TTs because I'm wondering whether I need to trade this off and cash in my ENTIRE life savings in order to start fresh and RIGHT for a used travel trailer weighing no more than 2700-2800 lbs dry. I will NEVER buy another trailer from a private individual again.
