AmericaOverland
Jan 19, 2015Explorer
Imagine two PCV poles with a medium-duty tarp, one pole hung on top of the foldout door lip and the bungees attached to the center grommet and the frame underneath. I made it 8 ft wide and had the bottom pole extend about 3 inches below the hinge. When I go, I can roll up the cover and stow it in the compartment (while the tarp is 8 ft wide, the poles are a bit shorter than that so it will fit).
I did find out after climbing up there and looking closely at the door seal that it's toast. You can see the side edge of the door from above! I went to the local RV store to get them to attempt to order a new seal from the factory, as none of what they have or what I found online matches what I'm looking for, shape~ and dimension-wise.
44,071 PostsLatest Activity: Aug 30, 2026
