er78mph's avatar
er78mph
Traveling to Freezing Temperatures
Hello and thanks to all in advance!
Next week we'll be leaving SoCal and heading up to Yellowstone. I've never camped in sub below freezing temperatures and wanted some pointers. I have plenty of propane, decent battery bank, and 200 watt's worth of solar. I also brought a Mr. Buddy space heater just in case. My main concern is water freezing in black/grey tanks. I bought RV antifreeze but not quite sure what to do? Should I just dump a few cups down each tank? Any advice would be truly appreciated, thanks and happy camping!
  • Ivylog's avatar
    Ivylog
    Explorer III
    It only looks like it will get down to 32...even if it goes much lower your water tanks are not going to freeze as there is too much volume. Now your water lines may if near the outside of the TT, but with the furnace on and cabinet doors open that should not be a problem for the few hours below freezing. I would not worry about it or do anything special.
  • Below freezing is one thing, sub below freezing must be really cold. The forecast I see is barely freezing.
    Keep the heat on, and no, putting a bit of RV AF in them won't help.
  • In my limited experience. The tanks wont freeze unless it is below freezing day and night for an extended period of time. It is the gate valves on the tanks that freeze so you can't dump.
    So you might try wrapping them in something to insulate them.
    When it happened to me. I headed west until it thawed.
