Bobbo
Nov 17, 2019Explorer III
garym114 wrote:
Just make yourself a ring jumper, one wire, connect + of house to + of chassis battery.
VERY bad idea. If you drain the house battery, you also drain the chassis battery and won't be able to start the MH to drive anywhere. The Trik-L-Start is a one way power transfer. It allows power to flow from the house battery (converter/charger) to the chassis battery, but does not allow current to flow the other direction. That prevents the house from running down the chassis battery. (It also doesn't let power flow from the house battery to the chassis battery if the house battery charge is lower than the chassis battery charge.)
About RV Newbies
