Matt_Colie
Nov 18, 2019Explorer II
Bobbo wrote:garym114 wrote:
Just make yourself a ring jumper, one wire, connect + of house to + of chassis battery.
VERY bad idea. If you drain the house battery, you also drain the chassis battery and won't be able to start the MH to drive anywhere. The Trik-L-Start is a one way power transfer. It allows power to flow from the house battery (converter/charger) to the chassis battery, but does not allow current to flow the other direction. That prevents the house from running down the chassis battery. (It also doesn't let power flow from the house battery to the chassis battery if the house battery charge is lower than the chassis battery charge.)
In our community, it is called a 1$ combiner. As the place it gets used is under one of the front hoods that should be checked before start up, we just don't worry about it. We also use alligator clips so it is easily installed on either the Isolator or the Boost contactor. One owner even bothered to put a long red "Remove Before Takeoff" ribbon on his.
Matt
About RV Newbies
