Grit_dog
Nov 21, 2019Trailblazer
^ Ah, I getcha now.
You're say IF the OP's rig has a solenoid that links the hose batteries to the start batteries he can wire the charger up to charge/maintain both at the same time.
That sounds simple and clever.
I'm not familiar with big RVs like this but would ASSume that the house batteries are already linked to charge from the alternator when the engine is running?
If they are then there may be a simple way to reverse that so the existing charger can power both sets of batteries.
If not, an automatic charging relay can be added where it links the batteries as soon as 1 side or the other see's charging power (>13.5 V or something) and then disconnects the link when it senses power below 12V to prevent discharge of both sides.
Blue Seas ACR is what i used in the boat for this.
About RV Newbies
