tractorboy924
May 15, 2013Explorer
ok. fridge as I thought, so I can purge most air via the burners. Got it.
Ice to kick start the cool cycle - Got it. I seen it run on shore power but have not tried Propane.
Water heater I had my daughter give me Model # atleast so I will look it up from there. maybe its NOT A/C as there are NO switches that I see for the HW tank.
Model SW6P so going to look up now and see if I can get manual or more info on it.
with the S presuming its a suburban. Thank you all. I may be only propane on the Hot water. Thanks.
UPDATE:
I do see its suburban got the manual right here. Looks like it DOES have electric but...I see NO switch inside the camper anywhere. i will have to do more digging. Its 20 years old the camper and I remember seeing the 12 or 14 gauge wire for the 120/AC maybe switch in burner compartment? show a light and switch in the wiring diagram.
hmmm Could this switch be on the battery/tank control panel??
UPDATE:
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
