HGL's avatar
HGL
TT Rear Bumpers
Ok...so being a bit new to things and only having our Outdoors RV Timber Ridge, I have a question. I see threads all over the place about not putting your bike rack on the bumper because the bumper will fall off....how?
When I look at my bumper, its at least a 1/4 thick steel with solid welds back to the frame. I would have to look under it to see if it has extra bracing, but curious minds want to know.
Thanks for all of the questions.
ps. Our bikes ride in the back of the trailer strapped to the wall where the bottom bunk folds up.
  • With about 150lbs of bikes hanging 2 feet out past the bumper, all that leverage will twist and tear the bumper apart! Now I have 4 bikes on the back, but they are secured so they do not bounce which is what will tear a bumper and/or rack apart! even if you put on a trailer specific hitch to the frame you still need to secure the rack so it will not bounce!
  • Check again, I think you'll find that steel is no where near 1/4" unless someone has replaced it. It will be more like 16 or 18 gauge and now days, it's not even a true steel tube but just a formed square with a few spot welds.
    The welds are another story. Do they look like caulk that has been laid down in a smooth bead on top of the metal? Most of the time the welds like like that and have no penetration.
    In my own case the bumper simply peeled itself away from the weld in some places and in others, the weld snapped free.
