the_bear_II
Feb 10, 2015Explorer
Most private campgrounds as well as some state & national will show the available channels on the campground map or other info they hand to you as you check in.
I usually raise the antenna and leave the amplifier off. Turn the antenna to see if you get a signal from a station and then flip the amplifier on. Turn the antenna to fine tune and then check other channels and fine tune until you get the best signal on all the available channels. I've even lowered the antenna slightly to improve reception in a couple of spots.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
