JohnG4706
Feb 10, 2015Explorer
Again, I thank the experts!
Something that appears so simple is more complicated than you originally think.
The Antenna Helper looks to be a very good source. I've already downloaded it and will try it out this weekend.
I'm also interested in the Winegard Sensar Pro. If I understand the installation correctly, the Sensar Pro replaces the original interior cable box and shows signal strength.
The antenna raising handle is in the front bedroom, about 15 feet from the interior cable box. How do you zero in on the optimal signal when you can't see it? (I've heard the King antenna has their strength meter built-in the their raising mechanism.)
Again, thanks for the info.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
