Dutch_12078
Feb 10, 2015Explorer III
JohnG4706 wrote:
I'm also interested in the Winegard Sensar Pro. If I understand the installation correctly, the Sensar Pro replaces the original interior cable box and shows signal strength.
The antenna raising handle is in the front bedroom, about 15 feet from the interior cable box. How do you zero in on the optimal signal when you can't see it? (I've heard the King antenna has their strength meter built-in the their raising mechanism.)
Again, thanks for the info.
The SensarPro also has an audio tone that changes pitch as the signal gets stronger or weaker. It also includes an inline amplifier that further boosts the signal from the antenna. Be aware that the default gain setting of '10' is the midpoint of the scale. Raising it to 20 gives you the maximum 10dB gain.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
