We want to get a tv for our travel trailer. It has a wall bracket installed already. Do we need to shell out for the more expensive "rv tv" (Jensen??) or will any lightweight flat screen work?
Any flat screen will work as noted above. Stick with the major brands and avoid the off-brands.
BUT: A few are designed to work off 12 volts while the majority are for 120 volt. So you need to decide what you will be running the TV off of. I have a 120 volt TV that I run off an inverter when 120 volt is not available. That's what most folks are doing.
