We want to get a tv for our travel trailer. It has a wall bracket installed already. Do we need to shell out for the more expensive "rv tv" (Jensen??) or will any lightweight flat screen work?
Some smaller LED TVs, like up to about 26", use a wall wart to convert the 120vac to 12 or 14vdc for the TV. You can run these directly off the 12v power in the RV by not using the wall wart and connecting the TV directly to the 12v. Just make sure the wall wart outputs the correct voltage.
