newcomers's avatar
newcomers
Um, more on generators?
I read the closed forum on generators and learned a lot, everyone seems to like champion. I had done some reading and found solar panels are often used to keep the battery charged, and I found a solar generator that can store power so I wondered why not use one for keeping stuff running quietly. Has anyone had any experience with solar generators in their RV's?
  • Very interesting when I checked out the link from Thats OK I seen that the solar generator is basically an inverter that has a lead acid (AGM) battery built into it... I think I will stay with the original solar panel concept
  • What things do you want to run? If you want a/c you will have to go to something around 3500 watts. Maybe a little less but it depends on manufactures etc.
    If you just want microwave and maybe a smaller hairdryer you may go 2000 watts.
    If you want to stay out for say a week or so and just keep your battery up from using lights, water pump, ceiling vent you could go small and cheap.
    If you are staying away from high draw items and dont want a big solar system, solar may do what you want.
    If I was running my led tv or computer off it I would hesitate on the cheap one and get a Honda or Yamaha.
    Dont go buy something from just what I said here. as you are doing, educate yourself
    Others in here know A LOT and can help out.
    They need to know what you are trying to accomplish.
    LOL I'd leave the solar generating to the sun...kidding wit u of course.
    Cindi I'd go camping in the RV once or twice before getting confused about buying an add-on AC power source.
    The DW, dawgs and I trailered for almost 2 years in NFS or state park areas before eventually getting a small generator.
    My advice to you:
    Don't buy everything until your convinced it will enhance the experience :)
    Can you tell us more about the 'solar generator' (make, model, web site...)?
  • A so called 'solar generator' is simply a solar panel, inverter, and battery combined for a ridiculous price. Stay away.
    Everything you need to know is on the forum, sit back, and plan on many hours of reading, there are no new questions.
  • Before you do anything you need to figure out how many watts you truly need. With out knowing how many watts you truly need it's hard to help someone.
    From what I understand about solar generators it's a battery and an inverter with a high price tag. I forgot there set up for solar to help mess with people. The few that I have read put out very little power.
    Why not go with solar on the trailer, upgrade your batteries, and install an inverter. If the system is not sized properly you will end up having to use a generator.
