parkmanaa
Dec 09, 2015Explorer
Quality of the ride is based more on having the right inflation pressure for the load the tires are carrying. Weigh the rig when it is loaded for camping, go to the tire manufacturer's website and find the PSI they recommend for your load.
Add 5% safety facto0r, and that is actually the correct pressure you should use.
BTW, if you want to upgrade to the best, check the Michelin X RIB 16" tires.
About RV Newbies
