jfkmk
Oct 17, 2013Explorer II
No pump required, it is all a gravity dump. Get a good sewer hose kit (I have a Rhino Flex, everyone has their own preference). Get a box of disposable nitrile gloves and always use them just in case. Let the black tank fill completely before you dump so the flow of the liquids helps empty the solids. Dump the black tank first. This will allow the water in the gray tank help to wash out the nasty stuff from the black. After the black tank is completely empty, close the valve and open the gray tank valve. Never leave any of the valves open while you're hooked up. For periodic cleaning, I bought a wand you put down the toilet. It has a spray head on it that spins and cleans the tank. It's all pretty easy, and the RV dealer should go over the whole thing with you. Just keep that black tank clean to avoid bad odors.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
