Bumpyroad
Oct 29, 2013Explorer
locster wrote:azjeffh wrote:
If you NEED disposable gloves, you're dumping technique needs to be adjusted.
So touching piping containing fecal matter then touching door handles and faucet knobs on your RV afterward is a good idea? Your plumbing connection may be clean, but are you sure you know what is on the drain cap at the campground?
those fittings are always clean on the outside since I give them a good lick after use.
bumpy
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
