path1ExplorerDec 30, 2015Water filters in horizontal position, it is OK?Mounting filters in a horizontal position. Will they work or is this wishful thinking? Thanks
TodduptonExplorerDec 30, 2015It will work but depending on the filter type you may not be able to replace the filter if it is on its side.
Related ContentTC Horizontal LP CylindersHorizontal 20 lb. propane tanks.Horizontal Swinging DoorsFiltered Positive Pressure To Keep Dust Level Downoil filter?
