Camper_KenExplorerMay 19, 2015Water heater - how long should it run?With my previous motorhome when using the water heater on gas it would take an average of 20 minutes for it to heat up and shut down. Now with my current motorhome it's more like 45 minutes or more be...Show More
FrankShoreExplorerMay 20, 2015If you want to (or are capable of this) run both the gas and electric heaters at the same time - this will get your water hot in a hurry!
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater Problem
