tpi
May 20, 2015Explorer
Camper Ken wrote:
With my previous motorhome when using the water heater on gas it would take an average of 20 minutes for it to heat up and shut down. Now with my current motorhome it's more like 45 minutes or more before it will shut down. Both water heaters are Atwood 6 gallon models. When I check the temperature of the water after 15-20 minutes (hand under the running water) it's very hot. Is this possibly a defective thermostat on my current model?
Mine is completely dependent on the outside air temperature and the water temperature in the tank before heating. I've had the range of time you've experienced. I also recommend checking water temperature making sure it is in spec.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
