Only_True_MosnoExplorerSep 25, 2016Water Heater Drain Valves..are they worth it?So I was thinkng of replacing the plastic nut that you remove to drain your hot water heater with one of the brass drain valves by Camco. After reading reviews on Amazon I now am wondering if it is ac...Show More
katysdadExplorerSep 25, 2016Don't put anything but a nylon plug in a Atwood water heater. Dissimilar metals will freeze in the aluminum tank fitting.
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Water Heater Leak on start up.Water Heater Problem
