njtonyExplorerApr 17, 2017water heaterMy Atwood water heater (2013 coach ) has started to emit soot from the exhaust system. What could be the cause ?
MFLNomad IIApr 17, 2017It could be bugs, bug nesting, something plugging up the burner pipe, causing a poor fuel/air mixture. You may need to remove pipe, clean out/blow out, something causing an obstruction. You want to see a good mostly blue flame.Jerry
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsSmelly Water HeaterWater pump?Suburban SW12DEL Water Heater On/OFF switch melts???
