Remove burner tube
Remove main orifice----soak in alcohol then blow dry (Not with high pressure compressor just whistle)
Clean out burner tube with small bottle brush
Run wire thru combustion/exhaust chamber....tie rag to wire and pull back thru 'U' tube
Install orifice
Install burner tube....align it so it is straight with gas valve/want gas to flow down center of tube not bouncing off wall of tube. If crooked gas/air will NOT mix properly
Check spreader plate on end of tube...should be parallel to end of tube
Light of WH burner....loosen screw on air shutter and adjust air mixture
Close off slots if REALLY LOUD BRIGHT BLUE flame
Open more slots if YELLOW LAZY Flame with soot (unburned fuel)
Flame should be Blue with tinges of yellow tips
