vkatzman
Jun 06, 2013Explorer
Water Hookup and Water Pump Problems
We camped this weekend at Ponderosa State Park near McCall, ID. The park has full hookups, but when we attached the hose and turned the water on, there was a squealing noise coming from the coach connection (the water pump was off) and we had low water pressure inside the coach. Knowing that we couldn't listen to that noise while we were camping, we disconnected the water supply and filled the coach's fresh water tank and turned the water pump on. When using the bathroom faucet and sometimes the kitchen faucet, the water pump would fire rapidly and the lights would flicker. Didn't happen while using the shower or flushing the toilet.(We were plugged into a 30 amp connection which may or may not have anything to do with our water pump problem). Now we are plugged in at home and the bathroom faucet is still causing the rapid fire pump sound. Any suggestions would be appreciated. Thank you.
