path1 wrote:
RV's supposed to be checked by manufacture to 55PSI (I believe is the latest) when being made.
Here is latest water mess...
Curious - where did you read that?  I thought it was tested much higher like 90 or 100 psi.  Maybe they test at 55 but should be able to withstand much higher.  I have our Watts regulator adjusted to 60 psi upon the recommendation of RVwaterfilterstore.  Pex, pinch clamps, fittings and faucets should be good for at least 100 psi.
CG water pressure can get pretty high sometimes and I've read as high as 200 psi.  We had 120 psi somewhere this season.  If you don't use a regulator sooner or later you could have a big problem on your hands.
The low cost inline regulators aren't really regulators and are just a flow restrictor and all they have is a small diameter orifice inside.  Pressure will equalize on both sides in a static state.  I am going to make up a demo setup in the near future to demonstrate this.  A "real" regulator like a Watts is the only way to go.
