rblake39's avatar
rblake39
water pressure regulater
Purchasing our first RV and we are looking on Amazon for accessories. Just wondering what the max water pressure was for a typical RV? Should I buy the cheap one that allows 40 to 50 pounds of pressure or get an adjustable one with a gauge in case we need more pressure? Thanks
  • For many years I used the simple water regulator like this:
    I actually had 2 of them. I never had any problems with over-pressure and the lines in my camper exploding or anything. I thought it worked pretty well.
    Then one time, we stayed at a KOA. The manager warned us to be sure to use a water regulator on our camper as the water pressure at the spigots was 110 pounds and that would blow out our lines if we didn't use a regulator.
    It was at that point, I had the "Ah Ha!" moment and realized I didn't know how trustworthy that device REALLY was.
    EVER since (and it's been a few years now), I don't attach a hose to my camper. I fill the fresh water tank and pump from there. When it gets low, I fill again. I may leave my water hose laying on the ground, but it's not attached.
    I know some folks will probably chime in with some pretty sophisticated water pressure regulator suggestions, with gauges, and valves, and settings, and everything else. But simplicity is the best. Isn't it? Your on-board pump will not over pressurize. I prefer to be 100% safe and never have to worry about it.
    Several years ago, we had a garden hose burst on us. I had the regulator between the hose and the camper. If it would have been between the spigot and the hose, it might have saved the hose. Something to think about? Where do you place the regulator?
  • Bobbo's avatar
    Bobbo
    Explorer III
    Go to The Water Filter Store and get an adjustable, a Valtera, or, better yet, a Watts. The Watts can be rebuilt if it ever fails. Set the pressure to 45 psi to 55 psi. The RV manufacturers usually recommend 45 psi, but the pumps nowadays come set to 55 psi. I called Winnebago and asked about 55 psi and they said that was fine.
    The Watts X65BG is the new model of the regulator I have. I recommend it. I am happy with brass. I would not pay extra for stainless steel. Brass has been used with potable water systems for generations.
