jarata1
Aug 14, 2016Explorer
water pump isnt working
My water is coming out fine with a city water hose hook up but when I go to the water pump nothing.How can i tell if water pump is bad.I can tell its on its humming just not pumping water
SoundGuy wrote:jarata1 wrote:
I did that can here the pump go on but doesnt pump water to sink or shower.I wonder if that valve being bad doesnt allow pressure to build up enough for pump to be effective
Once the city water inlet is sealed with a threaded plug it's then irrelevant to pump operation. Check to see if the pump will achieve prime as I suggested earlier ... if it doesn't then there's a leak somewhere other than the city water inlet since it's been sealed.
