sonuvabug's avatar
sonuvabug
Water Pump - Not working right - well sorta
When using using the fresh water tank with the 12v water pump (no city water pressure), the water pressure/flow gurgles and flows very slowly as observed by looking at the lines themselves and by the flow at the end of the faucet.
The lines gurgle when engaged but the pump doesn't shut off as when the line is fully pressurized. You can hear the electrical motor running but that deep sound of the water pump running is largely absent. My guess is the pump motor (electrical bit) are fine ... it's just the pumping bits (diaphragm or impeller?) that is broken.
Any ideas and is there a kit to replace just the pumping bits?
