Old-Biscuit
Sep 10, 2018Explorer III
Air leaks only occur on pump SUCTION side
Any leak on pump DISCHARGE side would result in water leaking
Pump casing, suction strainer, suction hose clamps/fittings etc
And if pump is a Shurflo 2088 model.......obsolete/out of production several years ago/no parts.
So if you need to replace cause pump casing is cracked etc then get a Surflo 4008 (3gpm/55psi) or 4088 (4gpm/55psi)---direct replacements
