BTPO1
Jul 02, 2014Explorer
tearza wrote:
I finally unplugged the wires at the water pump an it no longer comes on but the rocker switches keep lighting up an I have to keep turning them off. Has anybody ever had this problem?
If this is a single control station (one Switch) then it is possible that the rocker switch is worn out and in need of replacing. I would replace it and see if your problem is solved. Rocker switches are not that expensive. JMO
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
