4x4van
Jul 03, 2014Explorer III
tearza wrote:
Before I unplugged the water
pump outside it would be activated when these switches lit up...
Now I'm really confused. What do you mean "unplugged the water pump outside"?
As for the switches, the chance that 3 momentary switches for a latching relay are all going bad at the same thime is nil, although I suppose it could be the relay itself going bad. Does everybody in your RV KNOW that they don't need the water pump on when you are hooked up? That's a common misunderstanding; Someone may think they need to turn it on to use the water. Either that, or someone is messing with your head and turning them on when you're not watching. Piss off your wife recently?;)
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
