Hello all, New to RVing here. I plan on only using my rig when it is connected to water and power. I do not plan on doing any boon docking. With that being said when my water is connected to the c...
When connected to shore water you don't need to use your water pump.
You should always place a water pressure regulator between your rig and and the shore water supply - also remember to turn off the shore water at it's source if your leaving the rig for any time - otherwise if there is a break in one of your plastic fittings the shore water will flood the rig.
