BemotaExplorerAug 10, 2015water tasteWe purchased a FW a couple mos. ago. This is our first FW (had slide-in), anyway on walk-thru the tech showed how everything worked, everything worked. When we got home I noticed there was some pink s...Show More
DOTLDaddyNomadAug 10, 2015Are you saying that when you drained the water heater, it was full of pink anti-freeze? If so, whom ever winterized the FW was an idiot. :S As far as the taste, I would just do the fill and drain method, repeat as necessary.
