tenbear
Feb 04, 2015Explorer
Dutch_12078 wrote:tenbear wrote:Dutch_12078 wrote:
I solved both the hot and cold shower restart issue (two different motorhomes) by installing check valves where the water lines connect to the shower faucets. The problem occurs because one line or the other has a slightly higher pressure than the other, probably due to upstream fixtures, so when you turn off the shower head valve, the higher pressure line forces its source back down the other line for some distance until they equalize. The check valves prevent the backfeeding. I used PEX check valves from Watts/Sea Tech that required just cutting the lines and pushing the ends into valve bodies. Just make sure the arrows are pointing towards the faucets.
How about a link? :@
My apologies for not seeing your post sooner! I found Watts check valves at a local True Value store, but here's an online source if you need it: Seatech Check Valve 1.2" CTS
The Watts and Seatech fittings are the same product sold under both names.
Thank you.
About RV Newbies
