Jbrowland's avatar
Jbrowland
Water too hot during Navy shower
When taking Navy showers I click the little button to stop water flow to wash but when I turn it back on via the water flow button the water is extremely hot when it comes out for about 15-20 seconds and then returns to where I set it when I started the shower. Is this normal? If not, what could be causing this? The only thing I could think of is maybe the hot water pressure is stronger.
I haven't noticed yet if this happens while dry camping but it did happen when hooked up to water and electric. We use a pressure reg on the hose.
I can deal with this but my worry is fo my daughter.
Stumped. Thanks!
  • Jbrowland wrote:
    Is this normal?
    Yes.
    When you stop the water flow completely - the end with higher pressure at the controls - hot or cold - will saturate the hose over a couple minutes.
    Keep a small drip running to keep the water are the set temp.
  • Mine comes out real hot also... Thinking the hot water side's more pressure due to + temp is the cause but not sure.
  • hummm---not sure why yours come out hot at first. Mine comes out cold for about 2 seconds before returning to the set temp. Could you possibly just turn the flow rate down and not off? Maybe that would keep the water temp the same.
  • We like to let our shower head drip into a plastic quart container slowly, then you use the drippings for the navy shower as required. It tends to make for a more even temperature and with care, the amount used it likely less too.
  • On ours, instead of an off button, we installed a nice matching brushed nickel flow control valve and then hooked the show hose to the valve. This allows us to keep a slight water flow going and avoid a sharp water temperature change - ours was going too cold. For your daughter who might not be able to reach that high, you may be able to install a valve at the shower head?
    Bill
