njtonyExplorerOct 05, 2020Water valvemy son just bought a coleman tt 2021. When trying to get water from water heater found out the valves only work when part way open. Weird. If you turn valve all the way either direction you get no wat...Show More
Old-BiscuitExplorer IIIOct 05, 2020Sounds like RV MFG used 3-way valves1/4 turn to open, close or direct flow Very common type of valve usedExample: uses two 3-way valves *in Bypass Mode (handle points in direction of flow)
Related ContentWater pump?Why no hot water?toilet water valveDometic 320 water valveWater Heater Check Valve
