njtonyExplorerOct 05, 2020Water valvemy son just bought a coleman tt 2021. When trying to get water from water heater found out the valves only work when part way open. Weird. If you turn valve all the way either direction you get no wat...Show More
kellemExplorerOct 05, 2020Definitely weird and have to wonder what justifies a 3-way.Every trailer we've owned (4) have had the simple open and close with a alternate bypass valve. Note:Make sure the bypass valve is in the closed position to avoid cold water invasion.
Related ContentWater pump?Why no hot water?toilet water valveDometic 320 water valveWater Heater Check Valve
