njtonyExplorerOct 05, 2020Water valvemy son just bought a coleman tt 2021. When trying to get water from water heater found out the valves only work when part way open. Weird. If you turn valve all the way either direction you get no wat...Show More
wopachopExplorerOct 05, 2020Are you guys thinking its the setup with only 1 valve and the water heater exit has the built in check valve?
Related ContentWater pump?Why no hot water?toilet water valveDometic 320 water valveWater Heater Check Valve
