Mrs_Rosas's avatar
Mrs_Rosas
We finally decided to join the RV lifestyle!
Hello fellow RVers,
My husband and I are in our early 50's. I retired from the federal government early last year and he's still working. Although we are new to RVing, we are veteran tent campers with too many items that were meant to make our camping experience more fun and enjoyable. As a result, after our last, and I do mean "last", tent camping trip, we decided to make life easier for ourselves and buy an RV. This has been our dream. We had been looking around for a bit and had an idea of what we wanted. Being that this was going to be our first RV, we wanted a gently used RV that was reasonably priced. And we found her less than a month ago: a 2002 Fleetwood Tioga with a slide and less than 40,000 miles on it. We are so thrilled about our new toy and have decided start out slow by taking a couple of local trips until we get to know how everything works and how this Class C handles.
So what's my question? I have a lot and don't know where to start. I would certainly appreciate some ideas and thoughts from the veterans out there on #1) the absolutely have-to-buy-to-have-on-hand items and #2) what do we have to watch out for since this is an older model? Since we are having problems cranking up the generator without the help of the engine, we figure we'll probably have to replace the auxiliary batteries soon. That being the case, any recommendations on solar panels for when we are "dry camping" or is it called "boon docking?"
I'm sure I'll have more questions as we get to know this coach and we certainly appreciate any and all valuable info. We'd like to benefit from your experiences. Appreciate your time and words.
  • A few degrees below freezing should not cause damage, however if I am concerened and I havn't winterized if it gets dowm below high 20s I either turn the furance on or put in a space heater. Better to be safe than sorry.
  • welcome to the forum.
    I'll tell you what. We filled the RV and now I'm trying to empty the RV as I certainly went overboard,
  • You have not had a comment on the generator so far. Being a 11-12 year old RV and in AZ. there s a good chance the hose from the fuel tank to the generator s brittle, cracked and letting air in rather than only gas. Rubber rots and ages more quickly in heat. You can try to start it with a short piece of good hose in a gas can. If it runs that way you know the hose is bad. The other rubber hoses in the RV should also be checked to prevent accidents on the road where they are expensive repairs. You also need to have the gas tank over 1/4 tank for the generator to draw gas. That is so you don't run out of gas while parked in a CG.
  • You will probably find that the RV'ing community is very helpful to newbies.
    I'm not sure if I was just fortunate or if it's commonplace, but I had two experienced guys who were semi to permanent RV dwellers give me several lessons on my basic systems. They claimed it was fun to help out beginners and didn't mind.
    I suspect you will find many like that, so if you get in a bind, ask one of the more permanent looking set ups in whatever RV park you wind up in for advice. And I do recommend going to a park with full hook-ups at first.
