RoyF
Jun 23, 2019Explorer
If you want to run your furnace then the fan will use a lot of juice. The 3000ec will be a good choice IF (1) it is in good condition (I would have a Honda dealer check it out first) and (2) if you can cope with the weight.
If weight is an issue, one Honda 2200 or 2000 is easy to pick up (unless you have a bad back) and is enough to power the furnace and lights.
I don't know how many hours you would need to run a generator, but get a digital voltmeter and keep your battery at 80% capacity or better. (The 12v-side-of-life link will have information about voltage vs. capacity.)
About RV Newbies
