lanerd
Jan 29, 2014Explorer II
darsben wrote:
an easy rule of thumb to narrow down your search is that;
A) MOST automatic transmission cars ARE NOT flat towable without some sort of modification..
B) Standard (stick) transmissions are usually flat towable with no or small modifications
This is pretty good advice.. however, I would change the word "Most" to "Many" and also any modification done to either an auto or manual trans would be the same.....saying std shift trans may need "small" modification is a little misleading. FWD cars would need a lube pump and RWD cars would need a drive shaft disconnect.
The are MANY GM, Ford and even some Chrysler products that have auto trans that are 4-down towable. Not many Asian cars with auto trans are 4-down towable.
Good luck
Most popular are Jeep (several different models and Honda CRV's
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
