2014screw wrote:
I am getting the Equal-i-zer WDH and I am estimating my tongue weight will be between 600-650 lbs after all is said and done.
When looking at their website on the How to Select the Correct Hitch Size for Your Trailer - http://www.equalizerhitch.com/About%20Equal-i-zer/hitchsizes.php#results it has a section asking how much weight behind the rear axle of your tow vehicle
I input the following data
Gross trailer weight @ 4800 lbs
Tongue weight @ 13% is 624 lbs
Maybe 100 lbs behind rear axles on tow vehicle
The bars for this WDH are 600 and the next is 1000 lbs
Which one would you choose?
Those inputs into that link give you the 10K/1K hitch so what is your question?:h
Larry
